خالد تميمي
2024-08-20 23:41
Looking to buy a 2019 long-range model in the Pearl River Delta area, with a white interior and six or seven seats. No accident cars, don't try to fool me! Urgent purchase.
If the later designs of the SAIC Maxus T60 and T70 resemble the interior layout of the Ford Ranger, sales would definitely go up. After all, pickup trucks are considered commercial vehicles, not regular cars, and they require annual inspections. In many areas, there are restrictions on trucks, which is quite frustrating, and not many people are willing to buy them. I don't even dare to drive my own T60; each time I drive, I risk losing 3 points. Sigh...
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Looking to purchase a first-hand Chery Jetour X95 2020 model, seven-seater, with no accidents and no water damage!
Hey, anyone here bought a shooting brake? I'm into the Tasman Blue, flagship 2WD with red interior [smirk]. Go ahead and buy it, if you don't like it, I'll take it off your hands as a second-hand purchase [heart].
With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
Tesla Tesla Model X
Tesla Model XAED 342,000 ~ 397,000Electric
