محمد صعب
2023-08-05 07:41
Is it necessary to do wheel alignment after picking up the car? I did some research and found that issues with the camber angle can lead to inner tire wear. Not sure if the new model has this problem?
محمد صعب
محمد صعب2023-08-13 13:34
Tesla employees replied that the old models need it, but the new models have improved rear suspension, so it's not necessary anymore.
حسين أبو بكر
حسين أبو بكر2023-08-06 04:17
I suggest you get your vehicle's alignment checked, as it pulls to the right straight off the line.
After changing to new tires, the steering feels heavier. I always used Continental CPC2, but switched to Goodyear Assurance (also did a wheel alignment). It doesn't veer off course, but the steering feels heavier, and the accelerator is also heavier. For those who've changed tires, how do you feel about it? Also, a reminder: wheel alignment is a maintenance service, not mandatory. If you choose to do it, make sure to check the shop's equipment and skills. I feel it wasn't really necessary this time.
Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
Tesla Tesla Model X
Tesla Model XAED 342,000 ~ 397,000Electric
