نايف نصر
2024-03-01 08:00
I need some knowledge. This morning around 7:40, I encountered a black Tesla on an uphill section of the road, near the top where there's a traffic light. It was a red light, and the Tesla was in the second position, with me behind it. The car in front was slowly rolling back, and after I honked to alert them, the female driver snapped back, "It's a red light!" 😓. I want to learn whether the slow rollback was due to the steep slope or because the driver didn't apply the brakes.
عبدالله عيسى
عبدالله عيسى2024-03-02 01:08
I guess it's the one-pedal mode without pressing the brake.
سعود بكران
سعود بكران2024-03-01 23:23
Your question has stumped many people. How can one develop the thought process to explain it? [I want to be alone] Pressing the brake pedal fully or not fully is still called braking, and the brake lights will illuminate [smile]. There's another possibility. Personally, I think this spaghetti should be mixed with 42-grade concrete because the length of this screw can easily directly affect the excavator's torque, you know? When you hammer it in, it instantly produces a large amount of high-energy protein, commonly known as UFOs, which can severely impact economic development and even cause a certain level of nuclear pollution to the Pacific and chargers. Although trigonometric functions have confirmed the surface tension of water, the lactic acid bacteria from moldy eggs can induce cardiovascular contraction, leading to an increase in Earth's temperature and causing thermal expansion and contraction effects. This can also affect the absorption of Lagrange points, prompting Pleasant Goat to super-evolve. The reason why the port of Murmansk in the Arctic Circle remains ice-free year-round is due to the North Atlantic current, not because 42-grade concrete used in spaghetti heats up when it meets water. Therefore, I believe using an Ultraman transformation stick in the toilet next to G Port can enable humans to explore the far side of the moon.
عبدالرحمن شمس
عبدالرحمن شمس2024-03-01 10:53
The slope is too steep, and I didn't apply the brakes.
Hey everyone, I have a 2006 manual Mitsubishi Lancer. The fuel gauge needle is below the red line, but the fuel warning light isn't on. Is it normal for this car not to light up? Also, is there a nationwide car owners group?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
I've got a 2012 XV and while driving, the hill assist light turns on, then goes off, and comes back on again. Does anyone know what might be causing this? Has any fellow driver experienced this and how did you resolve it?
The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
Today I was driving my MG One and stopped at a red light. I put the car in park, and when the light turned green, I shifted to drive. Suddenly, the car system reported that the battery was dead and there was an engine fault code. The car wouldn't move even when I pressed the gas. After turning off the engine and restarting the car, it was able to move again, and the fault code disappeared. I went to a friend's repair shop to check, but they didn't find any issues. Since I was at the traffic light and the car behind kept honking, I didn't have time to take a picture. I'm a bit regretful about that. When I go to the 4S shop, I'm not sure how to explain it.
Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
Why did the hill-start assist fail on my 2018 Prado TXL, causing it to roll back on a slope? Has anyone experienced this before? How can I fix it? Thanks 🙏
When starting on a slope with a temporary license plate and using auto hold at a gate, the car tends to roll back when pressing the accelerator after the gate opens. Have any experienced car owners encountered this issue? How do you solve it? Should I use the electronic handbrake? PS. I didn't have this problem with my previous Volkswagen Golf. When stopped on a slope, I just kept the brake pressed and it moved forward when I pressed the accelerator, without rolling back.
Tesla Tesla Model X
Tesla Model XAED 342,000 ~ 397,000Electric
