سلمان عبد له
سلمان عبد له
Aug 6
Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
Comments( 6 )
عبدالرحمن فريد
عبدالرحمن فريد2024-08-26 10:37
Official data is relatively conservative, with actual loss ranging from 2% to 4%. In fact, initial degradation shouldn't be a major concern.
عبدالرحمن جم
عبدالرحمن جم2024-08-19 09:25
Ten months and the battery health is at 92%.
محمد نصر
محمد نصر2024-08-14 19:12
I've heard that both the X and S have always used Panasonic 18650 batteries. The first 10% drops really fast, but then it slows down a lot.
علي شعبان
علي شعبان2024-08-12 03:43
Is the 4% decrease officially verified, or did you calculate that yourself? I've driven 70,000 kilometers, and it's only around 4% for me.
حسن همام
حسن همام2024-08-08 07:47
You should fully charge your laptop battery once every two weeks to help redistribute and balance the battery capacity.
عبد العزيز هلال
عبد العزيز هلال2024-08-06 20:34
This is useless. How should I use it?
The original battery in your Haima S5 from 2016, manual transmission, has been in use for six years. After being parked for half a month, you jump-started it with a power bank and have been driving it 50 kilometers daily for a week, but it still remains in a discharged state. If the car can't start after being off for more than an hour, it might be time to replace the battery.
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
I'm planning to buy the dual-motor version of X. Can you tell me how much the battery might drain if I don't use it for half a month?
Why doesn't such a big car use the CT5-V's 3.0T V6 gasoline engine? That's not very American. 🤦‍♂️ I can understand not using a V8, but going straight to a 4-cylinder, what's up with that?
Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
Tesla Model X
Tesla Model XAED 342,000 ~ 602,070 Electric & Electric & N/A
