Does anyone else's X compressor make a noise every few seconds? It makes a noise when turning the AC on or off, and also when locking the car. But it doesn't make a noise when the AC is off. The air conditioning is cooling normally.
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
Is it normal for the trunk to beep a few seconds after closing? The trunk is already locked.
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
4What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
5When I turn on the AC, it makes a noise... After a while, it gets a bit better, but when I stop the car, it starts making noise again... Has anyone experienced this? Thanks.
6During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
7Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
8What could be the cause of the Mazda 6 air conditioning compressor frequently cycling on and off and making loud noises?
9Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
10Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
