Can a home charger for the 2017 X90D charge the 2023 X Long Range?
Is the portable charger for this car easy to use? Can you just use an extension cord to charge the car directly?
I'm considering buying the 2023 Model X and I'm curious if the version with a 664 km range can still reach 600 km in the summer while using the air conditioning?
4Does the Model X have a 2019 Standard Range version? Is the suspension the new version? Apart from battery capacity, what are the differences compared to the 2019 Long Range version?
5Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
6How long does it take to fully charge the E2 with a slow charger? The range is 405 km.
7Is the Toyota bZ3 2023 Long Range PRO with 19,000 km non-commercial use worth 119,000 for home use?
8How long does it take to fast charge the Song 160 km version? What is the charging power and how long can the maximum power be maintained?
9What is the actual range of the 2023 Model X with 700 km?
10How long does it take to charge the 2017 100D if not using the Supercharger?
