Why isn't there a video explaining regenerative braking and single-pedal mode in electric vehicles? Many people are new to these features. Regenerative braking is also found in some petrol cars, like my Audi A6L. I once lost focus while going over a speed bump. My foot was on the accelerator, but the regenerative braking caused the car to slow down noticeably. I saw the bump was too high and wanted to brake, mistakenly thinking the current deceleration was from the pedal under my foot. I pressed down, but it was the accelerator, causing the car to surge forward. Luckily, there were no other vehicles on the road, or I might have panicked and caused an accident. I don't think I'm the only one with this experience. It seems similar to several reported Tesla brake failure incidents.
Does this car have regenerative braking, or is it like the Model 3, which only has regenerative braking when you release the accelerator? In other words, does this car have CRBS?
Will the brake lights illuminate during regenerative braking when you are not pressing the brake pedal?
Hey folks, has anyone modified the foot brake parking? I'm thinking of making some changes.
4Why does the brake pedal on the JAC Shuailing T8 not return to position? It works fine when I lift the brake pedal with my foot. What's going on? Does anyone else have the same issue?
5I want to know if the 2021 model has regenerative braking.
6What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
7Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
8Sudden braking causes noticeable bumps, and you can hear the fuel sloshing in the tank.
9Where can I adjust the regenerative braking strength of the Aria? How many levels are there?
10Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
