طه علي
2024-12-04 08:27
When turning the steering wheel while stationary or at a large angle, if you hear a noise from the chassis transmission ball joint, it could be due to wear or lack of lubrication in the ball joint. It's recommended to have it checked by a professional mechanic to diagnose the exact cause and address any potential issues.
There could be several reasons why your 2.9T6 steering feels particularly heavy. Common causes might include low power steering fluid, issues with the power steering pump, or alignment problems. It's also possible that the tires are underinflated or there's an issue with the steering linkage. It would be best to have a professional mechanic inspect your vehicle to diagnose the exact cause.
The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
Possible reasons why your car might not move when you accelerate could include: 1. Transmission issues 2. Low transmission fluid 3. Clutch problems (for manual cars) 4. Brake system issues 5. Engine problems It's best to have a professional mechanic check it out to diagnose the exact issue.
It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
Tesla Tesla Model S
Tesla Model SAED 359,000 ~ 466,990Electric
