When the 2023 model makes a creaking sound from the chassis ball joint while turning the steering wheel sharply at a standstill, what could be the reason?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
4Hi, what could be causing the steering wheel to make a buzzing sound when turning?
5Is it normal for my steering wheel to make a rustling sound when I turn it more than one full circle during a U-turn or while reversing? I just got my Seetus Luxury Edition 20 days ago.
6Changan CS35 Plus makes a strange noise when turning the steering wheel while stationary.
7Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
8Hey, fellow car owners! Have any of you experienced a loud creaking noise coming from the chassis when turning the steering wheel while stationary? I'm not sure if this is normal or if it's an unusual noise, but it's really loud and quite bothersome 😫
9When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
10What causes the steering wheel to make a noise when turning the shaft?
