أيوب خالد
Dec 22
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
Comments( 8 )
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
I'd like to ask Mazda 5 owners, why is the noise level so high in this car? How can it be resolved, and how do you deal with valve cover oil leakage? What are your Mazda 5's fuel consumption rates in the city and on the highway? My 2011 automatic Mazda 5 costs 0.9 RMB per kilometer in the city.
4Is there a rattling noise from the chassis when accelerating with the H7? Has anyone experienced the same issue?
5Hey fellow car enthusiasts, when I start my 2014 Scirocco 1.4 and give it a bit more throttle, there's a rattling "dada" noise and the car shakes. What could be causing this and where is it coming from?
6I have a 2015 CC, and it's very quiet at idle. But when I hit 70 km/h, the engine noise gets really loud. I'm not sure if it's coming from the engine or the chassis. I have to turn up the music to cover it up. I've already changed the oil in the chassis, but it didn't help. Has anyone else experienced this? Is it normal for a 4WD to be like this?
7Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
8When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
9The accelerator feels weak, and the control arm is making a rattling noise.
10After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
