أحمد عيسى
2024-11-12 16:32
Why are physical gear levers and wiper controls being removed? Will the new model Y include them?
How do you remove the gear knob from this car? I want to replace it with a new one.
Why does the 2023 Sequoia have a gear lever?
When I put my Smart Forfour into reverse, why does the rear wiper keep running? I checked the wiper lever and it's definitely turned off. Why does it keep wiping when in reverse? Does anyone know what the issue might be?
Has the front screen of the new HiPhi been removed? It's one of its most unique features. I hope it continues to be included.
Cullinan or Model Y? The Cullinan looks very grand, but the Model Y, being fully electric, saves on fuel costs and also has an advantage in terms of acceleration from 0 to 100 km/h. I'm torn.
Does anyone know how to upgrade the central control of the 2017 model to include CarPlay?
To replace the dust cover on the gear lever of a 2018 manual transmission ZS, follow these general steps: 1. **Remove the Gear Knob:** First, unscrew or pull off the gear knob, depending on its attachment method. 2. **Detach the Dust Cover:** Carefully pry off the trim panel around the gear lever to access the dust cover. This might require a trim removal tool to avoid damaging the panel. 3. **Remove the Old Dust Cover:** Once the trim is removed, you'll see how the dust cover is attached. It might be clipped or screwed in place. Remove any fasteners and take off the old cover. 4. **Install the New Dust Cover:** Position the new dust cover in place, ensuring it's aligned correctly. Secure it with the clips or screws you removed earlier. 5. **Reattach Trim Panel:** Pop or screw the trim panel back into place around the gear lever. 6. **Reattach Gear Knob:** Finally, screw or push the gear knob back onto the lever. Note: These steps are a general guide. It's always best to refer to the vehicle's manual or consult a professional for specific instructions related to your car model.
Does anyone know what the W button next to the gear lever on the 2019 automatic model is for?
When is the new model being released?
Why is the plastic near the gear lever on the passenger side very hot?
