When starting from a red light in standard mode on a rainy day and pressing the accelerator pedal all the way down, there is a jerking sensation. What could be causing this?
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
I've been having heavy snow here the past couple of days. The car starts to skid once the speed goes over 20. Neither the snow mode, standard mode, nor sport mode seems to work. How about you guys?
When turning the steering wheel all the way to the right while reversing, it feels like the wheels are rolling over something, with an up-and-down sensation, similar to the feeling of an uneven tire.
4What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
5Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
6Is the lumbar support of the standard 14-way seats on the 992.1 unable to fully retract into the backrest? Even when adjusted all the way in, it still sticks out and presses against the lower back. It's really uncomfortable over time.
7What causes a jerking sensation when gently pressing the accelerator?
8Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
9My 2018 automatic ZS sometimes shakes when waiting at a red light after the vehicle warms up. Between 60 to 100 km/h, the car feels like it's being pulled back, and there's a strong jerking sensation. If I press the accelerator hard to over 3000 RPM, the jerking stops. Using cruise control to accelerate also avoids the shaking. Is this a transmission issue?
10Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
