حسين معتصم
2023-09-06 17:15
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
فهد جواد
فهد جواد2024-08-23 21:18
Spark plugs and ignition sound
عيسى خالد
عيسى خالد2023-09-23 16:59
Belt?
محمد عوادة
محمد عوادة2023-09-11 10:40
Sometimes it's there, sometimes it's not. Anyway, I don't worry about it. I've only replaced the battery once in 6 years.
نايف فريدة
نايف فريدة2023-09-07 16:33
When I start my car, the idle speed is high, but after warming up for half a minute to a minute, it goes back to normal.
2
خالد طاهر
خالد طاهر2023-09-07 00:35
I just want some peace and quiet for now.
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
When you warm up your car or are idling at a red light, can you hear a "tatata" sound inside the car? Sometimes it's there, sometimes it's not. It's not the engine sound. Even if you press the accelerator a bit, the "tatata" sound frequency stays the same. Not sure what's causing it.
Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
Gv80 shifts to neutral at a red light, makes a thump sound when starting.
How can I turn off the low-speed warning sound on the Toyota bZ3? It's so annoying, especially late at night!
The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
When shifting from D to neutral, there is a clicking sound. What could be the problem?
Is it normal for a used 2021 Forester to noticeably shake from side to side when revving in neutral?
Mitsubishi Mitsubishi ASX
