When you warm up your car or are idling at a red light, can you hear a "tatata" sound inside the car? Sometimes it's there, sometimes it's not. It's not the engine sound. Even if you press the accelerator a bit, the "tatata" sound frequency stays the same. Not sure what's causing it.
Comments( 7 )
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
4Do you also hear noise from the engine while inside the car?
5Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
6After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
7Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
8Is it normal to frequently hear a low-frequency buzzing sound while driving the Taycan?
9When you hear a clunking sound after turning the steering wheel, what's going on?
10Has anyone experienced idle speed being sometimes high and sometimes low? When I'm waiting at a traffic light, sometimes it's 7500, sometimes 9500, and this is without the AC on. The last two times, right after refueling, the idle speed was 9500. Not sure what's going on.
