فهد هلال
2024-08-14 16:08
When you open the fuel cap of your 2014 ASX and hear a sound of air being sucked in, it could be due to the pressure difference between the inside of the fuel tank and the outside air. This is usually normal and can happen because the fuel system is sealed to prevent fuel vapors from escaping. If the sound is frequent or you're experiencing other issues, it might be a good idea to have it checked by a professional.
علي حارثي
علي حارثي2024-08-15 18:51
Is it hot outside?
10 Mazda 3 Star Version 2.0 frequently has the warning light on, with an instant fuel consumption of 30-40 at startup. Spark plugs, intake manifold solenoid valve, rear oxygen sensor have been replaced, throttle body and mass air flow sensor have been cleaned, but the light comes on again. The first row mixture is too lean. Any suggestions?
The check engine light is on for your 2010 Mazda3 hatchback, and the fault code indicates that the fuel trim system is too lean after the catalytic converter. Here's what you can do: 1. **Check for Vacuum Leaks**: Inspect hoses and connections for any leaks that might be causing the issue. 2. **Inspect the Oxygen Sensors**: A faulty oxygen sensor can lead to incorrect fuel mixture readings and should be checked. 3. **Examine the MAF Sensor**: The Mass Air Flow sensor might be dirty or malfunctioning, affecting the air-fuel ratio. 4. **Look at the Fuel System**: Check the fuel injectors and fuel pressure to ensure they are functioning properly. 5. **Check the Catalytic Converter**: Although less common, a failing catalytic converter can cause similar issues. 6. **Professional Diagnosis**: If you're unable to identify the problem, it may be best to consult a professional mechanic for a thorough diagnosis. Remember, addressing the issue promptly can prevent further engine damage.
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
If your manual transmission 2.0 car with 120,000 kilometers is making a metallic clashing sound above 80 km/h, it might be related to the transmission chain. However, manual transmissions typically do not have chains; they usually have gears. It might be a good idea to have a professional mechanic check it out to pinpoint the exact issue.
Is there pressure in your ASX's fuel tank? When I open the fuel tank, there's air coming out.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
When I went to refuel, the fuel cap wouldn't open after I parked. I couldn't press the brake when starting the car, and it also showed an engine fault warning. It took seven or eight tries to get a response. What's going on? Any ideas?
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
Mitsubishi Mitsubishi ASX
