محمد ثاني
محمد ثاني
Jul 31
Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
Comments( 6 )
عبدالرحمن خدي
عبدالرحمن خدي2024-10-30 05:27
Try replacing the rear main control arm bushing (the biggest one). I have a 2013 model from 2015 with a manual transmission, and it worked for me!
علي فايز
علي فايز2024-10-01 14:56
My car makes noise at low speeds too, but I haven't found the issue.
حسين سلمان
حسين سلمان2024-09-12 17:33
Bro, I have the same issue. Have you found out the reason?
عبدالرحمن شعبان
عبدالرحمن شعبان2024-09-08 20:04
Does the car make noise when it's parked and the engine is running?
خالد طاهر
خالد طاهر2024-08-01 00:19
Does it not make noise at low speeds?
خالد طاهر
Nope. [I want to be alone] [I want to be alone] [I want to be alone]
When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
Does your car have this kind of noise? The engine is making a strange sound. I suspect it's the VTC gear making noise.
Why does my 2.0 engine consume 7.4-7.8 liters on the highway at 130-140 km/h and 8 liters on national roads, while it only consumes 6-7 liters?
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
Mitsubishi ASX
Mitsubishi ASXSAR 65,000 ~ 97,755Gasoline & Petrol
