سلمان مستنصر
2023-09-28 20:02
My car has been driven 90,000 kilometers since 2013. It's shaking when idling, and there's a jolt when shifting from Neutral to Drive. Has anyone else experienced this issue? Could it be time to replace the engine mounts?
محمد حارث
محمد حارث2023-09-29 16:57
My car jerks when I shift into D or R gear, but there's no shaking at idle.
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
Mitsubishi Mitsubishi ASX
