خالد عاطف
2024-06-17 22:54
My 2018 Mitsubishi ASX suddenly has an issue with the multifunction buttons on the steering wheel. When I press the next track button, it switches to the previous track. Pressing the previous track button takes me to navigation or the radio. I replaced the Android head unit three weeks ago, and everything was working fine after the replacement. The issue just started today. I'm not sure if it has anything to do with the new head unit. Does anyone know how to fix this?
عبدالرحمن نور
عبدالرحمن نور2024-07-24 00:53
Go to settings and re-learn the steering wheel buttons. It's a settings issue.
سعود بدر الدين
سعود بدر الدين2024-07-08 09:04
Replacing the central control screen requires reconfiguring the physical buttons.
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
I got a GS7 two-wheel-drive Luxury Smart Edition. Can anyone tell me if there's no manual adjustment for the headlight height? Also, the fuel tank cap won't open. It used to, but now pressing the button doesn't do anything. What's going on?
Hello fellow car enthusiasts! Can the 7-inch head unit of the T60 be replaced with the 10.1-inch factory head unit of the T70? After the replacement, will all features (such as voice activation and remote control) be functional?
Has anyone experienced the compass not working after replacing the original head unit? Any solutions?
Can anyone confirm if it's possible to replace the Elite version's head unit with a high-end one?
The multifunction buttons, such as volume up and down, next and previous track, and media buttons, are all not working.
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
Has anyone replaced the head unit on the 2021 model? The wired Apple CarPlay often disconnects on the road, making it hard to use.
Mitsubishi Mitsubishi ASX
