Is there pressure in your ASX's fuel tank? When I open the fuel tank, there's air coming out.
How to deal with a fuel tank cap pull ring that won't open, and I can't find the emergency pull ring in the trunk.
How to open the fuel tank cap on a 2019 Ford Territory?
4Where is the fuel tank switch on the 2013 City? Do you just press the fuel tank cap to open it?
5Does anyone know about the 2013 ASX 1.6 manual having issues with fuel tank overflow and carbon canister leakage causing the car to stall?
6Is it true that you can't open the right middle door when opening the fuel tank cover on the Sharan 2.0 standard model?
7Hey fellow car enthusiasts, how many kilometers can you get out of a full tank on a 2013 2.0 Mitsubishi ASX?
8I just bought a used 2016 Santana, and I'm trying to figure out how to lock the fuel tank cap. I realized it can be opened no matter what I do.
9When you open the fuel cap of your 2014 ASX and hear a sound of air being sucked in, it could be due to the pressure difference between the inside of the fuel tank and the outside air. This is usually normal and can happen because the fuel system is sealed to prevent fuel vapors from escaping. If the sound is frequent or you're experiencing other issues, it might be a good idea to have it checked by a professional.
10After running and turning off the car, when I open the oil cap, there's a faint white mist coming out. Does this happen to you guys too?
