Is it normal for the clutch of the 1.6 Jinxuan manual to be particularly hard?
Is it normal for the Suzuki SX4 1.6 to show a fuel consumption of 12.4?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
Is the clutch on the 207 particularly high? Should I replace the clutch kit, or is this normal for the car?
4Is the clutch adjustable on the manual Changan Yuexiang?
5Hello, everyone. For the 2018 model with the 1.6 engine, do you find the clutch pedal heavy? Can it be adjusted?
6How is the manual 1.6 Touran?
7The clutch on my 2011 Suzuki SX4 1.6L manual is heavy. What's the issue? Is your clutch also heavy?
8How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
91. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
10Is it normal for the clutch of the 1.6 Jinxuan manual to be particularly hard?
