If your manual transmission 2.0 car with 120,000 kilometers is making a metallic clashing sound above 80 km/h, it might be related to the transmission chain. However, manual transmissions typically do not have chains; they usually have gears. It might be a good idea to have a professional mechanic check it out to pinpoint the exact issue.
What is the engine RPM of a Mazda 2 with a five-speed manual transmission when driving at 80 km/h?
Guys, does the 2015 Mitsubishi ASX Silk Road version have a belt or chain in the transmission?
Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
4If your manual transmission 2.0 car with 120,000 kilometers is making a metallic clashing sound above 80 km/h, it might be related to the transmission chain. However, manual transmissions typically do not have chains; they usually have gears. It might be a good idea to have a professional mechanic check it out to pinpoint the exact issue.
5When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
6Possible reasons why your car might not move when you accelerate could include: 1. Transmission issues 2. Low transmission fluid 3. Clutch problems (for manual cars) 4. Brake system issues 5. Engine problems It's best to have a professional mechanic check it out to diagnose the exact issue.
7Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
8The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
9Once the speed reaches 80, there's a lot of wind noise, and the doors feel like they're leaking air, but I can't find the exact spot. Is this a common issue or do the doors have a problem?
10When driving on the highway, if the steering wheel starts vibrating when you exceed 100 km/h and the vibration becomes more pronounced at 120 km/h, it could indicate a few potential issues. It might be related to wheel balancing, alignment, or tire issues. You might want to have these checked by a professional to ensure safety.
