فهد هلال
2024-01-25 07:59
I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
Mitsubishi Mitsubishi ASX
