سعود حسين
2024-01-02 20:04
I've been driving a 2015 ASX and need some advice. The car starts just fine, but once I pick up speed and then suddenly brake to slow down, when I press the accelerator again, it feels like there's no response at first. There's a sudden jerk before it accelerates, making the driving experience really bad. Could it be time to change the transmission fluid? It's been 7 years and 45,000 kilometers, and I haven't changed the transmission fluid yet.
عبدالله سعود
عبدالله سعود2024-01-07 23:45
It's quite common. Initially, the wheels are driving the engine, but suddenly, the engine takes over and starts driving the wheels.
I've driven 80,000 km. Is it time to change the transmission fluid? What type of fluid should I use?
Where is a good place to get the transmission fluid changed on a 2010 MDX? Thanks 🙏
I've been driving a Suzuki SX4 for over ten years, and now the fuel consumption is higher than before. When I press the accelerator, the RPM goes up, but the speed doesn't increase. I've changed the transmission oil, cleared the engine carbon deposits, and worked on the throttle and fuel injectors, but the RPM is still high while acceleration is slow. Are there any fellow car owners who have experienced similar issues?
How often should transmission fluid be changed?
Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
Mitsubishi Mitsubishi ASX
