I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
SAIC Maxus 2020 T60 2.0T diesel 4WD, 1.5 years old. There's a vibration noise coming from the center console when the RPM is between 1800 to 2000 in low gear. What could be the cause?
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
4When driving at low speeds with the AC on, the car, which has over 30,000 kilometers, experiences significant vibrations. This is particularly noticeable when frequently reversing or making turns. The steering wheel, door handle, and seats all vibrate. Everything is normal when the AC is off. Sometimes, when idling with the AC on, there's a loud buzzing sound that feels overwhelming to the ears and head! I always use 95-octane fuel. Have you encountered this issue? How should it be addressed?
5When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
6Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
7I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
8When I release the accelerator on my 2023 Vito with seven seats, there's a loud buzzing noise. Has anyone else experienced this issue?
9Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
10Does anyone else experience their engine roaring at 2000 RPM?
