Has anyone experienced noise at 120 km/h with the 2013 4WD flagship model? It sounds like it's coming from the rear of the vehicle.
Hey folks, has anyone experienced their V40 shaking at speeds between 100 to 120 km/h, but then it stops shaking once it hits 150 km/h? I have an 18 model T5 with 55,200 km on it.
Friends, when driving at 120 km/h on the highway, there's a humming noise coming from the chassis. What could be the reason? Bearings have been ruled out first.
What's your RPM at 120 km/h?
4When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
5When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
6Hi everyone, I have a 2013 Yuxiang, and I'm noticing the RPM is high. When I drive at 100 km/h, it's at 3100 RPM, and at 120 km/h, it's at 3500 RPM. How can I fix this?
7Has anyone experienced noise at 120 km/h with the 2013 4WD flagship model? It sounds like it's coming from the rear of the vehicle.
8For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
9What is the RPM at 120 km/h?
10Loud noise at 100-120 km/h.
