حسين عوادة
2024-01-31 20:09
Does anyone know about the 2013 ASX 1.6 manual having issues with fuel tank overflow and carbon canister leakage causing the car to stall?
Mitsubishi Galant with automatic/manual transmission, when put in gear, the idle speed is low and it seems like it's about to stall. What could be the reason? Thanks, experts.
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
What tires did you guys replace on your ASX? I've got a 1.6 manual that's seven years old, and the original Dunlop tires have aged.
The fuel tank capacity of the 2019 Haval H2 manual Fashion Edition is about 55 liters. What are your fuel consumption rates, everyone?
Does anyone know where I can buy a 1.6 manual engine? I need to replace it, otherwise, it'll have to be scrapped.
Is the 2013 manual Jetta considered fuel-consuming if it has a 55L tank, costs around 420 yuan for a full tank, and runs slightly over 600 kilometers, with city driving not exceeding 60 km/h?
Hey fellow car enthusiasts, how many kilometers can you get out of a full tank on a 2013 2.0 Mitsubishi ASX?
What's the fuel consumption for a 2013 Jetta 1.6 manual when frequently stuck in city traffic during commutes?
Mitsubishi Mitsubishi ASX
