Any recommendations for brake fluid?
After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
How often do you guys change brake fluid? Looking for advice!
4What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
5Hey guys, any recommendations for brake discs and pads for the 2019 model? 😊
6How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
7I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
8Hey guys, how many liters of brake fluid do you need to replace the fuel?
9Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
10How often should brake fluid be changed?
