محمد صلاح الدين
2024-11-01 16:21
After removing the aging rubber ring around the air filter of the 2.0 engine, the engine starts to roar and sound hollow above 1500 RPM. Could this be due to a gap causing the issue?
Comparing the 2004 Bluebird Sylphy 2.0 and the 2007 Passat 1.8T: 1. **Engine Performance**: - The Bluebird Sylphy 2.0 typically features a 2.0-liter engine, which might offer decent power and reliability for daily driving. - The Passat 1.8T comes with a turbocharged 1.8-liter engine, generally providing more horsepower and torque, which can result in better acceleration and performance. 2. **Fuel Economy**: - The Bluebird Sylphy might have slightly better fuel economy due to its naturally aspirated engine. - The Passat, with its turbocharged engine, could consume more fuel but may offer better performance. 3. **Driving Experience**: - The Bluebird Sylphy is often appreciated for its smooth and comfortable ride, suitable for everyday commuting. - The Passat, on the other hand, might provide a more engaging driving experience, especially with its turbocharged engine. 4. **Interior and Features**: - Both cars might offer similar interior comfort, but the Passat could have more advanced features, given it is a higher-end model. 5. **Reliability and Maintenance**: - The Bluebird Sylphy is generally known for its reliability and lower maintenance costs. - The Passat could require more frequent maintenance due to its turbocharged engine, but it is also known for its solid build quality. Overall, the choice depends on what you're prioritizing: fuel economy and reliability with the Bluebird Sylphy, or performance and features with the Passat.
Choosing your first performance car is an exciting decision! Here's a brief rundown of your options: 1. **2003 Subaru Impreza STI**: Known for its rally heritage, it's great for all-weather performance and has a strong AWD system. However, it might be older in terms of technology and features. 2. **2013 Toyota 86**: Offers a balanced rear-wheel-drive experience, known for its handling and driving fun. It's a bit less powerful but very engaging to drive. 3. **2014 Ford Fiesta ST**: A fun, nimble, and affordable hot hatch. It's smaller and great for city driving, with a lively turbocharged engine. 4. **2014 Volkswagen Golf GTI**: A well-rounded hatchback that combines performance with practicality. It's comfortable for daily driving and has a strong community and aftermarket support. 5. **2004 Mitsubishi EVO 8**: Another rally-inspired choice, with strong performance and an AWD system similar to the STI. It may require more maintenance due to its age. Your choice should depend on what you value most—whether it's all-wheel-drive performance, rear-wheel-drive dynamics, or a mix of practicality and fun. Also, consider maintenance costs, reliability, and availability of parts for these older models.
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
French car enthusiasts, I need your help. My 2.0 engine is making a strange noise. When I accelerate gently, there's no issue, but when I accelerate sharply, there's a "da-da-da" noise at around 2000 RPM. After a few seconds, when the speed picks up, it goes away. There's no noise above 3000 RPM, only during sharp acceleration. I bought it second-hand and didn't notice this sound before. If it's not a big deal, I'll just keep driving it for now. [Yeah][Cute][Cover face]
My Zhilong 2022 model 2.0 has reached 20,000 kilometers. When the engine is cold-started, there's a "dang dang dang" sound at 1500 RPM, but it's gone at 800 RPM. Is it the same for you guys?
I have a 2024 model with a 2.0 engine, and after modifying to a quad exhaust, there's a resonance between 2000-2400 RPM. It's more noticeable at high speeds, and the sound seems to come from the right rear exhaust in the cabin. Has anyone experienced something similar? The issue persists even after removing and reinstalling the exhaust tips, so it's not due to loose fittings.
Mitsubishi Mitsubishi ASX
