عبد العزيز عبد له
عبد العزيز عبد له
Nov 13
The original 360 camera quality is too poor. Has anyone tried replacing it or found other ways to improve it?
عبد العزيز زياد
عبد العزيز زياد2024-11-13 21:49
I've never changed it, just making do with it.
نايف فخرو
نايف فخرو2024-11-13 19:20
During the day it’s okay, and at night when the lighting is good, it’s fine. But when the lighting is poor, it doesn’t make much difference whether it’s there or not.
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
Hey guys with the 301, I'm feeling that the car noise is too loud. I just did maintenance two months ago and also replaced the tires with the original Giti 221. What's going on? The engine hood and trunk lid don't have any soundproof cotton. Would adding some help? Have any of you guys tried it?
Are you guys replacing your Yige's tires with the original ones or going for other brands?
The Jietu 90 has too many issues. At less than 20,000 kilometers, the one-touch start fails to work, and the 360 camera malfunctions, sometimes even resulting in a black screen.
Has anyone modified the sound system of the Haval Cool Dog Pro? The original isn't Yamaha and the sound quality isn't great. Has anyone replaced it? How many loudspeakers are there in total?
Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
Is it necessary to add a decoder for the Skoda Kodiaq's 360-degree camera, or should the original screen be replaced?
Should I replace the oil pressure sensor on a 2017 1.4T Sharan? Is the original sensor an improved version?
Is the simulated engine sound in the RDX cabin too loud for you? Is there a way to turn it off or any other solutions to address this?
MG 6
MG 6BHD 6,999 ~ 8,500Gasoline & Petrol
