عبدالله رامي
عبدالله رامي
Nov 15
The MG6 spare tire cannot be mounted on the front wheels, otherwise the transmission makes a clunking noise when driving. Is this an issue with the car itself or is there a problem with the transmission? The speedometer cannot exceed 5, otherwise it makes noise. Seeking advice from experts.
فهد صارم
فهد صارم2024-11-18 18:27
How much smaller is the spare tire compared to a regular tire, and what should the tire pressure be?
محمد يونس
محمد يونس2024-11-18 14:54
It doesn't make sense. Why can't you use a spare tire on the front wheels? I've installed a spare tire on the front wheels and it worked just fine.
فهد أيوبي
فهد أيوبي2024-11-18 08:41
Dual-clutch transmissions are only challenged at low speeds, not during high-performance driving.
عبد العزيز زياد
عبد العزيز زياد2024-11-15 22:23
Is the spare tire having issues? [I want to be alone]
After warming up my 2015 S5 1.5T, the transmission makes a "dang dang dang" noise when I give or release the throttle. Not sure what's wrong. They say it can't be fixed. Has anyone replaced the transmission? How does it feel to drive after the replacement?
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
The transmission is making a loud noise, like a whistle. I even changed the transmission oil, but it didn't help. Has anyone else experienced this?
Does your CX-5 make a cicada-like noise at low speeds, especially noticeable when coasting at 60? Have any of you experienced this?
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
Hey folks, when starting the car cold and switching from P to D, the transmission makes a clunking sound. Also, when parking and switching from D to P, the car lurches forward a bit. Any idea what's causing this?
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
Hi everyone, I'm a newbie here and I have a question. When you park your Panamera on a slope and put it in P, does it roll a bit and make a loud clunk sound when you release the brake? And when you shift from P to N, is there also a clunk sound? My new car makes a really loud noise. It's scary, I almost thought I got hit.
MG 6
MG 6AED 54,500 ~ 75,888Petrol
