سلمان تاج
2024-09-11 14:51
How's the driving experience of a manual 1.5T? I'm considering getting a used one.
عبد العزيز عَبْدُ الله
عبد العزيز عَبْدُ الله2024-11-11 20:40
My 2018 model is fuel-efficient; with a full tank, it can run over 700 kilometers.
عمر عامر
عمر عامر2024-09-13 10:38
The car's acceleration, driving experience, and handling are all pretty good. You should take it for a test drive.
حسن مكتوم
حسن مكتوم2024-09-13 09:03
This car is only worth buying with a manual transmission [smile]. I used to drive the second generation with an automatic, and the jerking was quite noticeable. However, the third generation switched to a wet dual-clutch, and the fuel consumption also increased.
حسين باسم
حسين باسم2024-09-11 16:22
The 1.5T engine with 169 horsepower and 181 horsepower provides sufficient power for daily driving with a manual transmission. Just be mindful not to floor the accelerator too hard, or you'll notice the turbo lag, with acceleration kicking in 1 to 2 seconds after pressing the pedal. The MG6 has an independent suspension on all four wheels, which definitely offers better handling compared to a torsion beam setup. The space in both front and rear seats is decent, just remember to adjust the seat lower if you're tall. Generally, anyone under 2 meters should be fine. The stock tires are likely Michelin quiet tires, which are actually good quality. Many new cars nowadays come with locally made economy tires.
