avatar-image
عمر محسن
Aug 27
When driving over 80 km/h and releasing the accelerator, I hear a consistent humming sound from the engine compartment, similar to the vibration of a phone ringing. Any ideas on what this might be?
علي باسل
علي باسل2021-11-09 17:49
Which model is it? If it's the 2014 model, you can just clean the throttle body. That will put the vehicle back into a 3-cylinder mode, without having to press the accelerator hard.
إسحاق فهد
إسحاق فهد2021-09-04 10:02
The gearbox should shift, but the gears won't go up or down. 🤔
When driving over 120 km/h, the steering wheel and accelerator cause numbness in my hands and feet due to vibrations. Even slight unevenness on the highway results in rhythmic vibrations, making my hands and feet feel numb.
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
2014 Peugeot 3008, 2.0, experiencing shaking between speeds of 60 and 80 km/h, similar to engine stalling. What might be the issue?
I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
Does anyone experience noticeable vehicle vibration when accelerating between 95-110 km/h on the highway?
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
Hey everyone, I have a 2011 Mazda5. There's a humming noise between 40 to 80 km/h. The bearings on both sides are fine, and the center support bearing has been replaced. Has anyone else experienced this issue?
Is anyone experiencing vibration from the sun visor area in the 2028 Mitsubishi ASX when driving over 80 km/h? How did you solve it?
When driving at speeds between 80 and 90 km/h, the car's chassis vibrates, but it becomes smooth again at speeds of 100 km/h. What could be the reason for this?
