What do the taillights of 10 models look like when lit? Can the ones on the trunk light up?
Is the trunk partition considered a downgrade? The overseas version of the trunk partition can be folded and stood up for easy access to the space below.
If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
When the rear fog light on the 2021 SAIC Volkswagen T-Cross 1.5L Comfort version is turned on, only one side will light up.
4The taillights look like those of a Sonata, similar to the Custo.
5Does the center part of the taillights light up on your luxury version at night, or only the sides?
6For Comfort model users, do your through-type taillights light up as a strip at night, or only on the sides?
7When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
8What do the rear seat latches of the Kodiaq look like? The original ones got lost.
9Is there a modification available for the 2023 model 1.6T where the middle part of the through-type taillight doesn't light up?
10Is it normal for the right taillight not to light up?
