avatar-image
محمد بكران
Dec 5
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
حسين ثابت
حسين ثابت2024-04-23 00:18
Check for carbon deposits, then switch to 98-octane fuel. There are 3 days each month when it is priced the same as 95-octane.
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
Why does the engine compartment of a 2010 model, registered in 2011, with 83,000 kilometers occasionally make a "da da da da da da da" sound, especially noticeable when starting and just before stopping after driving?
Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
The daytime running lights on the 2020 model can't be turned off unless the engine is off. Has anyone gone to a repair shop for modification?
Today, I'm not sure what happened. The headlights and high beams are not working.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
