علي ثابت
2021-01-30 15:00
محمد عبد الوهاب
محمد عبد الوهاب2021-04-23 23:09
Hello bro, I'm interested in your car.
20
أحمد عوض
أحمد عوض2021-03-23 08:16
There are settings in the main menu!
2
خالد عمار
خالد عمار2021-02-05 22:12
Bluetooth can only be used for calls, nothing else. How to set pairing on the steering wheel?
How do I connect Bluetooth on a 2010 MDX?
Would you dare to use the OBD interface to connect electronic devices with a head-up display function?
Can this car's infotainment system connect to a phone via Bluetooth?
How do I connect Bluetooth with my phone?
After connecting the V40 via Bluetooth, is there no sound from the navigation on your phone? Tried several times and you can only turn off Bluetooth.
Does the Vitara have Bluetooth connectivity for phones?
After the upgrade, I can't connect to Bluetooth, and no nearby devices can be detected. Has anyone experienced this?
I can't connect the Bluetooth system of my 2014 Nissan Sunny with my phone. It says the key or pairing code is incorrect. Does anyone know how to connect the phone to the Bluetooth?
