The charging system issue on the 2009 MDX flashes briefly and then disappears. Even after replacing the alternator, the problem persists. While driving, the charge level decreases and then recovers. It's really frustrating, is there any expert out there?
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
4If your T99's battery is seriously drained and loses power after just a week of being parked, there are a few steps you could consider: 1. **Check for Parasitic Drain:** Ensure that no electrical components are drawing power when the car is off. This might include lights, the radio, or other electronics. 2. **Battery Health Check:** Have the battery tested to see if it's in good condition. Sometimes, a faulty or old battery may need replacing even if the car has only run 12,300 km. 3. **Alternator Check:** Make sure the alternator is charging the battery properly when the engine is running. 4. **Battery Maintenance:** If the car is parked for long periods, consider disconnecting the battery or using a trickle charger to maintain the charge. 5. **Professional Help:** If the issue persists, it might be a good idea to consult with a professional mechanic to diagnose and resolve the problem. Dealing with battery issues can be frustrating, but these steps might help in identifying and fixing the problem.
5The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
6The charging system issue on the 2009 MDX flashes briefly and then disappears. Even after replacing the alternator, the problem persists. While driving, the charge level decreases and then recovers. It's really frustrating, is there any expert out there?
7How to deal with oil burning? Today, while driving over a bump, the car jolted and the screen displayed a warning: "Low oil pressure, please stop." The warning flashed briefly and disappeared when I returned to a flat road. When I checked the dipstick, the oil level was very low. I just had maintenance done 1,000 kilometers ago. How should I repair this situation with a 1.6 naturally aspirated engine?
