فهد حسن
فهد حسن
Mar 22
The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
نايف ميمون
نايف ميمون2024-06-24 01:02
Has the issue been resolved? I'm also getting these error codes, and it's really frustrating.
Have you guys ever experienced the ABS, four-wheel drive, engine, parking, and anti-skid lights turning on? What's the situation? Is it a sensor issue or something related to the ABS?
What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
Even after changing the middle exhaust pipe, the fault light is still on. What could be the reason?
Has anyone had the engine warning light come on? How did you deal with it?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
The engine warning light is on, indicating an oil leak. I changed the oil 4 days ago using 5-30w. What's going on? Does anyone know?
Acura MDX
Acura MDXKWD 13,499 ~ 22,999Gasoline & Petrol
