My catalytic converter is poisoned. Can any experts recommend a cost-effective vendor to replace it?
For the 2011 Suzuki Liana, if you're getting a catalytic converter fault warning, there are a few things you can consider. First, you might want to confirm the diagnosis with another mechanic to ensure it's indeed the catalytic converter that's the issue. Sometimes, other components like oxygen sensors can also trigger similar warnings. If replacing the catalytic converter is necessary and the cost quoted is over two thousand, you might want to compare prices from different repair shops or consider aftermarket parts, which can sometimes be more affordable.
The mechanic replaced the catalytic converter for me, but now the car lacks power when climbing and accelerating. Do I have to buy an original catalytic converter? The original one is quite expensive, over 5000.
4Hey everyone, could you recommend a cost-effective gasoline car for daily commuting? Looking for something within a budget of a few thousand dollars. Thanks!
5Have any fellow car enthusiasts encountered a situation where the catalytic converter has minor cracks, causing occasional exhaust emissions to go uncatalyzed and triggering the emission warning light? The mechanic mentioned this. I regularly use Carpol's catalytic converter cleaner, Liquid Gold, etc., so there shouldn't be a carbon buildup issue.
6What dashcam is everyone installing on the Trumpchi GA8? Can any expert recommend one?
7I'm a girl looking to buy a small SUV from Volkswagen. Can anyone recommend a cost-effective SUV for me? Thanks, everyone!
8The engine warning light is on for my 2019 car, and the diagnostic says the catalytic converter is aging. What should I do? Do I need to replace it with a new one?
9Hello fellow car enthusiasts! I bought my ZS at the end of 2019, and it has driven over 120,000 kilometers so far. Recently, it started showing a fault code indicating that the catalytic converter efficiency is below threshold. Has anyone else replaced their catalytic converter? What was your experience? Thanks!
10Hi everyone, I'm thinking about replacing the center console in my Xiaozhi. Any recommendations?
