عمر محسن
2022-07-27 23:04
Is it normal for a fan not to spin frequently? I had it replaced at a friend's shop, but it's still the same.
حسن شمس
حسن شمس2023-05-10 14:23
The fan only starts when the radiator circulates normally.
Is it normal for the accelerator pedal to make noise? I've had this issue since I first got the car, and it's really annoying. The dealership says it's normal. Fellow car enthusiasts, is this really normal?
Today, I went to the 4S shop to change the oil. When the car was lifted, I tried spinning one of the rear wheels by hand, but the other rear wheel didn't move. For a four-wheel drive, shouldn't turning one wheel cause the other to spin in the opposite direction, like the front wheels do? Can someone explain if this is normal?
Hey fellow car enthusiasts, what should I do in this situation? I've been to the 4S shop to update the software and replaced the water pump and fan, but the problem still exists. [crying][crying]
Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
Should I replace the battery at the 4S shop or do it myself? I'm torn.
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
