نايف زين
2020-10-14 13:47
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
خالد رأس
خالد رأس2020-10-14 15:03
If you notice uneven tire wear, like outer edge wear, and a wheel alignment doesn't solve the issue, you should check the control arms, stabilizer links, and the suspension system. These are the main parts that could have problems. When the car is loaded, observe the tire's stance for any clues.
20
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
Model X, 40,000 km. There's a consistent humming noise from the rear wheels while driving, most noticeable at speeds of 35-40 km/h. You can feel a slight vibration in the floor when sitting in the back seat. I've been to the dealership a couple of times for this, and the last time, the technician confirmed the noise. After checking, they said the half axles are fine and concluded it's due to tire aging. I've heard that 21-inch tires tend to wear unevenly and might need replacement around 40,000 km. The tires only have 40,000 km on them, and the tread still looks clear. Is this really possible?
Is it necessary to do wheel alignment after picking up the car? I did some research and found that issues with the camber angle can lead to inner tire wear. Not sure if the new model has this problem?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Is it necessary to rotate the front and rear tires at 45,000 kilometers?
Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
