مهدي نايف
Aug 2
I bought a 2010 MDX, and it has only run over 70,000 kilometers. Recently, it suddenly lost power, and the anti-theft system went off in the middle of the night. I took it to the repair shop and replaced the battery. A few days later, it lost power again. The repair shop thought the alternator's output voltage was low and suggested replacing the alternator. I replaced it as required, and the check results showed no issues. However, a few days later, it lost power again. Can anyone help me out?
Why is the front USB port sometimes powered and sometimes not, even after the 4S shop replaced it with a new one?
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
Does anyone know why there's a high-pitched buzzing sound inside the car as soon as it's powered on? It's been happening the last few days and it's giving me a headache.
4Are there any 18-year Honda City owners here? Could you take a picture of your car's battery? After my car was repaired outside, it wouldn't start after a few days. I suspect the shop might have swapped my battery.
5I've had my 2021 Jeep Compass for three years now. Last year, it was parked for half a month during the New Year, and the battery died, so I replaced it. In March this year, it was parked for over 10 days, and the battery was dead again. I replaced it with a new battery, and in May this year, after being parked for 9 days, the battery died again. What's going on?
6My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
72015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
8Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
9Does anyone with a V40 have a source for chassis bushings? I want to buy them myself and then find a repair shop to replace them.
10Hello everyone! I have a 2022 Pioneer Edition Toyota Asia Lion, and I recently installed ambient lights. A few days later, the car battery died. Does anyone have a good solution for this issue?
