Hey fellow car enthusiasts, with the 2023 GV80, has anyone experienced the steering wheel not returning to center on its own, needing manual turning back?
4Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
5Does your Alto automatically return to the center when you turn the steering wheel?
6I have a question for the owner of a BYD Song Plus fuel version. Does your car's steering wheel automatically return to the center after you turn it all the way while stationary and then start driving?
