The chassis is almost touching the ground. It can only drive on paved roads, right?
Is the entire series equipped with chassis lifting, and how high can it be raised? Can it handle rural roads when going back to the hometown during the New Year?
2016 MG GT 1.5 NA, the chassis makes noise when driving over slightly rough roads.
4Which car has a higher ground clearance compared to the GT? Considering the road conditions are quite challenging. 🤔
5Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
6Hello Greyja car enthusiasts, does anyone know what the ground clearance of the Greyja is? Is the chassis very low?
7Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
8Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
9What is the ground clearance of the Ex30's chassis? Can this car handle curbs that a sedan cannot?
10Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
