أحمد قنصوح
2022-12-10 19:32
I've been driving for two days without choosing carbon ceramic brakes, and it feels like I have to press the brakes really deep to stop the car. Do any other owners feel the same way?
محمد تركي
محمد تركي2023-01-15 13:19
Carbon ceramic brakes aren't all that magical. On regular roads, their performance is similar to steel brakes, and they might even be slightly worse when the car hasn't warmed up. They mainly excel on the track, where they can maintain braking stability and prevent brake fade when things get really hot.
أحمد هادي
أحمد هادي2023-01-12 16:31
Don't rush, take your time to adapt, and eventually, you'll feel that switching to carbon ceramic is the way to go. After all, safety comes first. [I need some quiet time]
سعود صعب
سعود صعب2022-12-13 01:14
I didn't buy it, so I don't know.
I feel like the braking on my car is a bit sluggish. Does anyone else have the same issue?
I have a problem with the brakes on my Volvo S80L. I've replaced all the brake fluid, but it still feels like the car doesn't stop well when reversing. The pedal is hard to press. Is it a clogged brake line, or could it be something else? Can anyone help analyze this issue?
Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
The 2023 standard version Rubicon has an issue where if it's left for two nights, the brake pedal becomes very hard in the morning when I press it to start the car. I'm wondering if anyone else has experienced this issue with their Jeep. I went to the 4S dealership, and they checked the vacuum pressure, which was at 620 and held for a morning without any signs of leakage. Is using a smoke machine the only way to check it? Sigh 😮‍💨
The noise at high speeds with the 2.0T engine is getting louder. I've had the car for two weeks, and it's currently at 2,500 kilometers. Does anyone else feel the same way? Any suggestions on how to fix it?
Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
Maserati Maserati MC20
Maserati MC20AED 950,000 ~ 999,000Gasoline
