سلمان أمينة
2019-10-30 08:12
10 Mazda 3 Star Version 2.0 frequently has the warning light on, with an instant fuel consumption of 30-40 at startup. Spark plugs, intake manifold solenoid valve, rear oxygen sensor have been replaced, throttle body and mass air flow sensor have been cleaned, but the light comes on again. The first row mixture is too lean. Any suggestions?
Comments( 9 )
حسين مكي
حسين مكي2020-03-02 11:37
Try disconnecting the power.
سلمان أمينة
سلمان أمينة2019-11-19 23:40
The battery terminal was loose. After tightening it, the issue never occurred again.
عبدالرحمن عدي
عبدالرحمن عدي2019-11-19 12:07
I also have a 2010 imported Mazda 3. When I reached 250,000 kilometers, I encountered the same issue. Later, I replaced the front and rear oxygen sensors with Japan's NTK ones. Now, I've driven over 290,000 kilometers without any fault codes appearing.
حسن ربيع
حسن ربيع2019-10-31 05:31
My old Mazda 2*0 also has this issue. I replaced a front oxygen sensor before, but it's happening again. However, it doesn't affect driving. I'm just going to ignore it since it's an old car.
سلمان أمينة
سلمان أمينة2019-10-30 08:37
Should I replace the upstream oxygen sensor with a domestic or imported one? The imported one seems to be from the NTK brand.
نايف رجب
نايف رجب2019-10-30 08:28
The engine mixture being too lean might be due to an issue with the front oxygen sensor. Replacing the front oxygen sensor should solve the problem.
عبدالرحمن علياء
عبدالرحمن علياء2019-10-30 08:25
This situation might occur due to insufficient fuel injection, excessive carbon buildup, or an issue with the oxygen sensor. To pinpoint the problem, you need to check each potential cause one by one.
أنس عبدالله
أنس عبدالله2019-10-30 08:25
It is very likely that your front oxygen sensor is damaged. Try replacing it, a new front oxygen sensor might work better. Alternatively, you can use a computer to read the fault codes.
عبد العزيز خديجة
عبد العزيز خديجة2019-10-30 08:16
If the air-fuel mixture is too lean, you need to consider both the air and the fuel aspects. This requires more testing than repairs. You should test the fuel pressure and the intake pressure. A common cause is a leak in the intake manifold.
Is the fuel consumption for the 2009 Liana 1.6 automatic reaching 10 liters per 100 kilometers because of a faulty oxygen sensor or carbon canister purge valve? I've checked the spark plugs and ignition coil, and there are no issues. Any advice from the experts?
The check engine light is on for your 2010 Mazda3 hatchback, and the fault code indicates that the fuel trim system is too lean after the catalytic converter. Here's what you can do: 1. **Check for Vacuum Leaks**: Inspect hoses and connections for any leaks that might be causing the issue. 2. **Inspect the Oxygen Sensors**: A faulty oxygen sensor can lead to incorrect fuel mixture readings and should be checked. 3. **Examine the MAF Sensor**: The Mass Air Flow sensor might be dirty or malfunctioning, affecting the air-fuel ratio. 4. **Look at the Fuel System**: Check the fuel injectors and fuel pressure to ensure they are functioning properly. 5. **Check the Catalytic Converter**: Although less common, a failing catalytic converter can cause similar issues. 6. **Professional Diagnosis**: If you're unable to identify the problem, it may be best to consult a professional mechanic for a thorough diagnosis. Remember, addressing the issue promptly can prevent further engine damage.
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
The 1.4T model keeps showing a fault light, and there's no 2nd, 4th, and 6th gear. The computer, valve body, and clutch have all been replaced, but the issue persists. How can this be resolved? Has anyone encountered this?
Why does the engine light keep coming on in my 2017 Kia Pegas automatic? After resetting, it lights up again after driving for a while. I've already replaced the oxygen sensor, but the problem remains.
I have a 2019 automatic RIO, changed the front and rear oxygen sensors, but after a few days the fault light comes back on! How did you guys solve this issue? What's your fuel consumption per 100 km? Mine is currently 10 liters per 100 km.
The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
Mazda Mazda 3 Sedan
Mazda 3 SedanAED 76,542 ~ 96,000Gasoline
