سعود عبد الرحمن
2022-01-15 09:53
Should I change the transmission oil for an automatic car that's been driven for 11 years?
نايف صباح
نايف صباح2022-06-11 21:19
You're quite something. [I need some peace and quiet]
خالد أنس
خالد أنس2022-01-22 18:55
Can be replaced.
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
Should I change the transmission oil for my 2012 Yizhi? It's almost 70,000 kilometers! Recently, I've been feeling some jerking while driving.
I have a question for everyone. I have a 2009 Honda City automatic 1.5. There's some jerkiness when shifting from 1st to 2nd gear, but it's better from 2nd to 3rd. Since it's a used car, I'm not sure how many kilometers it's been driven. Can changing the transmission oil solve this issue? How many liters are needed for a gravity change of the transmission oil?
For the 2021 Santana Automatic Comfort Edition 1.5L, how many kilometers should it be before changing the transmission oil?
Hey fellow car enthusiasts, my car is over seven years old and I haven't changed the tires yet. It's only been driven 60,000 kilometers. The tires are slightly aging, but I haven't driven much in recent years. It's mostly parked in the basement, so it's rarely exposed to the sun. Should I change the tires? I'm planning a long trip and am a bit worried!
How often should the transmission oil be changed?
