أحمد ميمون
2022-07-09 19:28
My March's right mirror isn't folding back automatically. It can fold out but not return to its original position. What should I do?
Hello, does your car's gear lever wobble? Also, can the side mirror folding feature be enabled in the system after locking the car? When I try to turn it on, it switches back off by itself.
Has anyone set up the key recognition feature? After I set up this feature, the seat doesn't return to the position it was in when I last got out of the car. What should I do?
This car should take a lesson from second-tier luxury brands and offer higher discounts. If the discount for the 70 model is around 80,000, it could firmly establish its position in the market.
Hey fellow car enthusiasts, with the 2023 GV80, has anyone experienced the steering wheel not returning to center on its own, needing manual turning back?
If you feel dizzy when looking at the left side mirror because it seems magnified, especially after switching your gaze from the right, it might be due to the mirror's curvature or your seating position. Consider adjusting either the mirror or your seat to find a more comfortable view.
When buying a used car, in addition to checking for any repairs or if the car is in its original condition and the overall structural depreciation, what else should you consider? Perhaps a knowledgeable mechanic?
Do you have any tips for fixing a car door handle that sometimes doesn't return to its original position after being pulled?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
Have you experienced an issue with your V60 where, after unlocking, the side mirrors unfold but don't return to the memory position?
