Is one part of the condenser wet? Could it be leaking refrigerant?
Where can I buy reliable parts for the S80? Can I buy branded parts instead of original ones?
Where can I find second-hand parts to replace a leaking Prius pressure cap?
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
4I want to buy one. Does this small city have the parts?
5Is one part of the condenser wet? Could it be leaking refrigerant?
6There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
7Hey Sportage owners, any of you experiencing a roof leak? Specifically in the rear part? Let's discuss it here.
8Are there any owners of the 2017 Skoda Octavia experiencing refrigerant leaks? The air conditioning suddenly stopped cooling.
9I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
