How many kilometers can a March engine typically run under normal conditions?
How many kilometers can a 2020 ASX 2.0 run on a full tank? Thanks!
How many kilometers can it actually run?
How many kilometers can a single fuel tank of an FJ72 run?
4How many kilometers can a 301 run with an additional 200 RMB worth of fuel?
5How many kilometers can a March engine typically run under normal conditions?
6Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
7How many kilometers can it run on a full charge and a full tank?
8How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
9I'm curious, how many kilometers can you typically drive on a full tank?
10How many kilometers should you typically change the transmission oil?
