سعود زين
Oct 6
I have a 2024 model with a 2.0 engine, and after modifying to a quad exhaust, there's a resonance between 2000-2400 RPM. It's more noticeable at high speeds, and the sound seems to come from the right rear exhaust in the cabin. Has anyone experienced something similar? The issue persists even after removing and reinstalling the exhaust tips, so it's not due to loose fittings.
After reaching a speed of 60, there is a constant hissing sound from the right rear side in my Arrizo 3. Is this due to wind resistance caused by a design issue, or could it be something else? Has anyone else experienced this problem?
When the 2018 F150 XLT makes a rattling noise when you release the accelerator while it's cold, but the sound disappears when the vehicle warms up, it could be due to several reasons. Since you've already replaced the timing components and the turbo, you might want to check other areas such as the exhaust system, heat shields, or engine mounts for any loose parts or issues. It's also advisable to consult a mechanic to diagnose the problem accurately.
Hi everyone, I have a 2016 3.6 Grand Cherokee. Recently, after switching to 0-20 oil, I've noticed a "doo-doo" sound coming from the exhaust area inside the car. It's not very noticeable when I get out of the car, seems like some kind of resonance. Also, after the oil change, the engine sounds louder. I've driven 400 km since then and there's no improvement. Any ideas?
4Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
5Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
6Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
7Hey everyone, I bought my car in December 2019. I haven't driven it much in the past two months, and it's been quite rainy. I've noticed some rust in this spot. Does it affect the car? Do I need to address it? Also, when I just started driving, it felt like one of the tires had a bulge, but after checking, all four tires seem fine. Has anyone experienced something similar?
8Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
9In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
10I have a 2024 model with a 2.0 engine, and after modifying to a quad exhaust, there's a resonance between 2000-2400 RPM. It's more noticeable at high speeds, and the sound seems to come from the right rear exhaust in the cabin. Has anyone experienced something similar? The issue persists even after removing and reinstalling the exhaust tips, so it's not due to loose fittings.
